Dennis in NH
I have the dual headlight mod no my 2008. I read how to install the headlight mod and see that to undo this mod I need to remove the extra wire going to the right side headlamp.
Basically, I removed the right side connector from the 3 prong bulb, removed the electrical tape, removed the wire, taped the wire off with the electrical tape, plugged the connector back onto the 3 prong bulb.
Now, when I turn on the bike, I get only left light on and if I switch to high beam, I get right side on. I figure I'm getting another 55 watts back and now I can hook up my heated jacket liner. I put the jacket liner on, turned it to full heat and voltage seems ok if I keep RPMs at 3-4K in neutral. We'll see how the commute goes this morning. I'll report back when I get to work.
Dennis
Dennis
