As the title says it all.. i lost my keys.:spank:.. what options do I have and what would it cost...
Really? He can't just call Yamaha and get a new key, with proof of ownership? You'd think that's possible...
Does your bike have the YISS/red key?
If not then you can replace the lockset. If it does then you need a new ECU too.
I don't believe that Yamaha has a record of key numbers against VINs.
I'm sure it is a US bike. Do they not have YISS?
so if I can summarize
- I can contact local Yamaha and they can get the key for me.
- Ask locksmith to make me a key
- Change the lock set
- Buy a new FZ6 :cheer:
Now
- Locksmith is ~ $90
- Changing lock set is ~ $90
Any idea what would dealer charge to get a key
Haven't messed with that since 2006 but the last I knew you had to have the 4 or 5 digit key code number that is on the key plus it comes with the little piece of metal that has it on it too. some times that code is also stamped into the ignition. I would try giving your dealer a call and see if they can help you, if not then I would try the locksmith. For all of you that have that metal tag write the number in the front of your owners manual and tape that tag on the inside cover as well! I keep my title and owners manual together.
Of course you could just go buy a new one.
