what are my options/cost -- lost keys
dev_usc
As the title says it all.. i lost my keys.:spank:.. what options do I have and what would it cost...
CHEMIKER
Running Moderator
San Jose, California (GMT -8)
youngy
Nowhere
Does your bike have the YISS/red key?
If not then you can replace the lockset. If it does then you need a new ECU too.
I don't believe that Yamaha has a record of key numbers against VINs.
I think it's a US bike.
How about the key code tag for the bike? That would have they code to cut a key. If you don't have it, a stop at a Yamaha dealer and a lookup on the bike's serial might pop a key code and you could have them make you one. Probably cheaper than a whole change out. There was someone here, recently selling an entire set-up with keys, ignition assembly, seat lock etc.
stevey722
Texas
on my 08 fz6 lost the key called the lock smith and in 3 hrs of him working on it lol he made me a new key fo 90 bucks. Didn't think they could do that but they did.
dev_usc
so if I can summarize
- I can contact local Yamaha and they can get the key for me.
- Ask locksmith to make me a key
- Change the lock set
- Buy a new FZ6 :cheer:
Now
- Locksmith is ~ $90
- Changing lock set is ~ $90
Any idea what would dealer charge to get a key
Now
I'm not sure the dealer can get the key code but it's worth a try.....
MoeDog
Modesto/San jose Ca USA
It might be easier and hassle free to just let the locksmith do it. Just have the guy GUARANTEE you that he can make one. if he cant do it then don't pay. just my 2 cents
2006_FZ6
Newport Beach, CA
I feel your pain! I lost the key to my Vino 125 scooter. I called a local dealer and they said if I can prove ownership they could send out and get a new key from Yamaha. I took the entire ignition switch off the scoot and took it and the title to the dealer. A few weeks they call me up and I have two new keys for my scoot.
I reassemble and it runs fine. I can't remember how much it cost, but it might be worth a call to your local Yamaha dealer.
08fz6
Make no excuses!
Central New york
Haven't messed with that since 2006 but the last I knew you had to have the 4 or 5 digit key code number that is on the key plus it comes with the little piece of metal that has it on it too. some times that code is also stamped into the ignition. I would try giving your dealer a call and see if they can help you, if not then I would try the locksmith. For all of you that have that metal tag write the number in the front of your owners manual and tape that tag on the inside cover as well! I keep my title and owners manual together.
2006_FZ6
Newport Beach, CA
There was a code stamped on my Vino's ignition switch! I forgot that's how the dealer was able to order keys from Yamaha.
Hope that helps a little. Of course you could just go buy a new one. :D
