just james
Where do you get these BD43 things for your headlights can you run both lights on low and high and how much are they ?
Motogiro's is easier, but BD43's is better (in my opinion) as it still allows the factory use of the high and low beam headlights. Basically, you just run a wire from the unused terminal in the headlight switch to the right headlight bulb. The wire can be routed any way you want to. For example, I have mine routed through one of the factory harness connectors to the fairing harness, then to the headlight. I taped everything up when I had the fairing off, so it actually looks factory.
Mine also uses the factory OEM set up and uses the factory high and low beam. It also works with all like H4/H7 configurations no matter what make bike.![]()
