- Joined
- Feb 7, 2009
- Messages
- 12,920
- Reaction score
- 1,725
- Points
- 113
- Location
- Cape Coral, Florida, USA
In all seriousness, with the introduction of "car" oil into this FZ engine, will the additives (not used in MC specific oil for wet clutch reasons), SOAK INTO the friction plates permanently?
I suspect it'd be fine after the oil /filter change, (hopefully the op will post the results) being it was only slipping at the top end RPM's.
I ask as some earlier FJR's had clutch plates stick (frictions) making shifting difficult. The fix was to pull the plates out and do a soak in MC oil which solved the problem.
