So I soldered some connections onto the tender and the lead to my battery after confirming the polarity with my new found multimeter skills. Well to be honest, I didn't trust myself 100% so I also disassemble the tender and checked the connections on the circuit board there was a convenient + and - sign and ran it back down the length of my lead. Delighted that I had got it right with my multimeter in the first place. The immediate problem I have identified is that there is now a potential grounding issue as the connections I purchased have bare metal once exposed once connected
I stupidly brought these instead if a bayonet type.
Anyway, I also found a straightforward cigarette lighter connection which I will wire in tomorrow.
I will of course check the polarity with my multimeter, but my logic is telling me that the spring on the side is the negative wire and the metal connector in line with the fuse is the positive wire? To test the polarity of the wires I was going to plug it into the hot cigarette socket already wired in and find it's positive and negative leads by running the power through the multimeter.
Please jump in armed with a wet kipper to slap me if I'm talking ****e.
Please bare with me on my electrical learnings as haven't even reach my puberty in this discipline.
