bdevries
You are a brave man! I once decided to polish them, got bored after 15 minutes of rubbing and nothing to show for it...
Seeing yours makes me want to try again, i tried to do it using wire wool the first time and it really didn't work, might try wet sanding this time.
Just realized you were using power tools! I went all hand and wire wool on it, which was just a massive waste of 15 minutes!
Might order on of them power cones and try the modern way.
Well, it wasn't all power tools.. all of the wet sanding and areas behind and in between were done by hand. Only way to wet sand is by hand but it gives quick results.. it takes it off quite quickly actually, I was surprised at how fast things went along once the wet sanding was being done!
