Up to a certain point, for sure, but don't forget that the R6 has at least 20hp
more and is lighter.
I've got +1 on mine and it really affected the acceleration in first gear, a lot
more then on my last bike (kawasaki ninja 650R, a twin), feels like I lost 10hp.
I think you're first one I've even seen to state this, "feels like I lost 10hp." Most folks say it has no impact which I have a hard time believing.
R6 -
The gear box ratios are different and depending on the year, they have an extra injector too. The late model is drastically different in too many ways to list...
IIRC the exhaust cam is near identical but the intake has different lobe centers and more lift, but not enough to change the valve springs.
The biggest benefit we could jack from the R would be the ECU and trigger wheel so we could ditch the group fire plugs and injectors. Theirs are more efficient but then you need to fuel pump and cams too! What do you gain? A more progressive ignition advance curve and better fuel delivery.
Sadly, even with the valve cover (it takes the same gasket as ours), cams, the COPs will fit but you'd have to drop the engine several inches to do a spark plug change.
Just to get the ECM in place:
Cams - cause we need the trigger
Camshaft position sensor
Valve cover - mounts the extra cam position sensor
Wiring harness
Ignition pickup and Trigger wheel
4X COP
Fuel Pump
Throttle bodies and intake
ECU
Gauge
But now the ECU is confused because the individual gears (1-6) all have different ratios. Why is this a problem; because the ECU uses the crank trigger AND the output shaft rotation per second to calculate fuel and ignition advance. Its how it knows what gear its in and "What to do". So the computer would be confused with the ratios so you'd likely need an external Fuel and ignition management to fix it.
I'm not 100% that this is a show stopper engine management wise, more so - something to consider. Hell, it may be happy and be better?!?
Its really far more complex than it looks Easier to take the whole bike or the engine and everything else needed.
- However, I am really wanting to get rid of the 1 ignition coil per 2 cylinders and run 4 individual Coil Over Plug Ignition Coils.
