55Watt HID Projector Lights With Hi/Lo
greymustang
IL
First I tried a set of street glow high watt bulbs but didn’t care for the effect of them. So then I thought to just go the full projector route and this is what I came up with.
I never could see very good before with the stock lights even with the high beams on it still wasn’t very good.
These work great a little cutting was involved but well worth the effort, I can see better with these then I can in my car.
These both have High and low beam’s and are still fully adjustable.
I’m thinking about putting in some LED’s but don’t know yet.
ctbandit
Fazer, don't even know er
CT
Looks great! A friend of mine recently did this to his zx6r and the light is amazing. Any links to where you sources the parts?
As far as wiring goes I'm assuming you put in some relays and tapped into the stock switch wiring?
DownrangeFuture
Electronic Repair Genius
Houston, TX
Bi-xenon Morimoto Mini Stage III Kit (H1) - Complete Retrofit Kits from The Retrofit Source Inc
That's the kit I used. You need the H4 adaptor plate and the H4/9003 relay. You only have to cut the shroud if you want to put that in there. Other than that, it fits right in.
EDIT:
Stickied in the Mods section: http://www.600riders.com/forum/fz6-mods/14963-bi-xenon-projector-angel-eye-installed.html
And my write up for the ones I used: http://www.600riders.com/forum/fz6-mods/37638-bi-xenon-projector-morimoto-mini-stage-iii-kit-install-my-new-mirrors.html
ctbandit
CT
DownrangeFuture
Houston, TX
$275, that's a commitment lol. Thanks for the link. This may be a down the road mod for me.
Yep but i'm keeping this bike for awhile. And when I do get another bike, the wife is probably getting this one, so it's going to be around until the wheels fall off probably. That and I commute at 5AM every morning, so it's still dark out.
And it's a lot less than an exhaust. :eek:
ctbandit
CT
Yea, def a worthwhile mod. :thumbup:
rsw81
Keep it Kosher
Boston, MA
I did a full custom projector retrofit on my FZ and it was by FAR the best and most useful mod I did on that bike. I only wish these kits were around when I did mine... would have saved a lot of time, effort, and money.:spank:
FIZZER6
The Angry Blue Mantis
Virginia
$275 for the best mod you can do on your bike if you ride at night.
This is the most worthwhile mod you can do on this bike for under $1,000 and it's $275 for everything you need! :thumbup:
I could never go back to the worthless factory lights.
DownrangeFuture
Houston, TX
I know, I was kinda sad when I saw the awesomness of the projectors. I don't think I can run factory lights in any vehicle I own ever again.
greymustang
IL
Later in the week I'll write a review on how I put everything in. Cost was about $150.00 was almost a plug and play kit.
