Thorak
Hey, I want to put risers on my handlebars but the ABS brake line is really short.
There is a local shop that can make a new longer custom brake line but I need to identify the fitting used on the 2007 FZ-6n S2. Looks like the master cylinder hose is permanently crimped to the fitting, and there is a screw crimp connection to the pipe that goes on to the ABS module.
I really want to make it as clean as possible and use the same type of fitting so I can change it back if needed. The part is about 16x16x23mm and there is a hole for a fastener through the top part.
The Yamaha microfiche only shows the brake line as one piece and does not identify the individual fittings.
Here are a couple of pictures, anyone knows if these are available anywhere?
