accesing battery with a full tank of gas...
nyctpt
NYC
I have a dead battery and of course a full tank of gas. When I lift the tank to access the battery will I get any fuel leakage/overflow?
Thanks
Ryan
raja777m
Ride like you own it..!
Charlotte, NC
I disagree. i've lifted the tank when it's full and didn't have any leakage. You should be all set.
Me too, I used 72" bungee cord with hooks to hold the tank straight, almost perpendicular to the bike.
I was scared first, but it didn't leak.
nyctpt
NYC
Thanks guys, gonna do it tomorrow morning so I'll let ya know how it turns out.
Ryan
elus1ve
Montreal
It does overflow (a few drops, not litres) through the hose when the tank is filled to the brim, but otherwise it will be fine.
nyctpt
NYC
Hardly lost any at all, just enough to leave a quarter sized spot on the ground. Lost one of the battery box bolts, any suggestions on sourcing one or what thread size they are?
Ryan
raja777m
Charlotte, NC
greg
UK Luchador
Stockport, UK
mountain bike disc brake bolts are the same fit and pitch
i've been using one on my bike since loosing one a few years ago
Ryan
They should be standard M6x1 metric(available at most Hardware stores). If the bolt you lost SHOULD have a shoulder, I'd order one from Yamaha or your going to squash the plastic. That or sliightly snug down and use RED loctite.
Parts 22 or 23?
Yamaha Motorcycle Parts 2007 FZ6 - FZS6W FRAME Diagram
nyctpt
NYC
I's the one with the shoulder of course. I might just try to find/make a bushing to take up the extra space. Thanks for all the info!!
Ryan
Ryan
If you have a local MC shop close, the shoulder bolts are VERY COMMON, especially that size.
I'd ask one of the mechanic's to peek thru their junk/spare parts box/drawer. I'll bet they'll have what you need.
(Just bring down the other one that matches the one you do have)..
Zealot
The Village Idiot
Canada, Ontario(GTA)
Ryan
Trial and error, a garage wide search, etc.
Take the other one to a hardware store and purchase a few of the closest looking ones you can. Alternatively, measure the threads per inch (takes a bit to count each ring) and the diameter of the bolt.
