MonteFZ6
- Joined
- Aug 6, 2016
- Messages
- 5
- Reaction score
- 0
- Points
- 0
- Location
- NorthCarolina at the beach
I have purchase a cheap knock off digital tach/speedo gauge. Halfway to completing the install. I'm not going to bother with the Gear indicator but I have successfully powered it, hooked up the high beam indicator, turn signals, and speed sensor. RPM works off of the signal from the CPS or right off the coil and the cylinder count is adjustable so its pretty universal. I'm having trouble locating the correct wire off the CPS or locating the CPS at all. I found a connector with one light grey wire and one dark grey wire. I tested both by bumping the starter but didn't see the tach bounce at all. I did the same with the coil posts but still didn't get a signal from simply bumping the starter. Do i need to have the bike running to test it? I currently have the tank off.
Also which of the two connectors on the bottom of the tank is for the fuel level? I know one is for the pump and the other for the level but I'm unsure which...
Lastly, the previous owner who laid the bike down has moved the ignition under the seat and had jerry-rigged a few things. There is a blue connector under the seat with two wire coming out of it and going into a smooth loom and down in front of the gear selector pedal. They have been spliced together. Is this the neutral safety switch? Can i find the neutral signal off this wire?
Here is the gauge:
52mm Universal Motorcycle Digital Odometer KM H Speedometer Gauge LED Backlight | eBay
Wondering if others have gone this route
Here is the gauge:
