dickieD
ive also heard city riding in a lower gear is better...
Okay witness the Hellgate thought process here...most often I'm wrong...
I think the key to getting better mileage is to make the engine spin slower at a given speed. A one tooth increase is about a 6.25% increase in final gearing, right? So...I would think that one's mileage would go up about the same amount, or from 45mpg to 47.5mpg-ish.
Thoughts???
When an engine spins at any given RPM you're using a set amount of fuel. If you set the same throttle at two different RPMs, the higher RPM will use more gas simply because the injectors are firing more frequently. If you can go the same speed with lower RPM, even at a slightly higher throttle setting, you're saving fuel simply because you're not squirting gas into the cylinders so often. Over 200 miles at 7000RPM this becomes a significant difference. Think of your throttle as a fuel governing device, and your RPM as a multiplier. 6000RPM x 10cc/min (lower RPM with higher throttle setting) is less fuel than 7000RPM x 8cc/min (higher RPM with lower throttle setting).
I wonder this as well... I have heard that 4k rpm is borderline lugging the engine and is not too good for the bike.. anyone?
I agree..take it easy on the throttle and be smooth...you'll do fine. This bike gets better mileage than my Subbie Legacey GT....25 mpg (2k on the clock)...so anything in the high 40's and low 50's is great by my account.....probably not going to spend much more time thinking about it either...just going to ride and enjoy!I appreciate all of the posts ya'll put up on this. Gas companies seem to be the only ones to make us look forward to three-dollar-a-gallon prices. When gas was a reasonable $1.50/gallon, for the good stuff, I would always opt for the regular at $1.30. Now that it is over $4, I fail to see the reasoning for buying regular for only 20 cents less. Putting things into perspective, at $2 per gallon, we were essentially getting twice the fuel mileage we do now.
This is an awesome bike, I am quite pleased with the $5,000.00 hit my checking account took in puting it in my garage. Perhaps the best way to increase fuel efficiency is the most obvious-take it easy on the throttle.
Mike
