Mancolt
I'm working on my bi-xenon install. It seems like I've run into nothing but problems. Luckily, they were more mechanical and I was able to work my way around them.
Now I'm doing the wiring on a kit that came with pretty bad instructions. I'm confused as to what goes where. I tried to take pictures of the setup so far. I don't think I'll have trouble with the ballasts. But the controller is what I'm not sure about.
I attached the picture of the controller with wires. If someone could explain where each one goes, that'd be great. I know where the ground goes, the battery positive, and the HID ballast, but I don't know where the "power of high light", "power of low light", or "power of caution light" go. I think I know where the unlabeled one goes as well.
My other question is what do I do with the brackets/connectors from the stock lights that connected to the back of each bulb? I'm referring to the ones that are female and have 3 slits to slide a male end into.
