Unfortunately no, they use a different mounting configuration (bushings). The OEM shock has a fully extended length of 12-7/8" (327mm). If you do a search in the forum you'll see that others have been able to adapt other shocks to the FZ6. If you find an alternative shock from another bike that has the correct length and bushing/mounting configuration, be sure to re-use your OEM spring. I say that because the FZ6 uses a direct linkage, whereas an alternative shock may have been off a bike that used a rising rate linkage.
