fazil
I've been making a shed, like a small garage these days. I bought a small arc welding machine and put some steel profiles, wood and concrete together.
Just like in the model below:
And the real photographs:
Now i plan to make some 6cm thin raw reinforced concrete walls between steel box profiles. I can make the concrete in three horizantal phases with 60cmx170cm plywood formwork. Welded the mesh reinforcement between profiles. Ready for formwork.
I also bought a sander to use as a vibrator for concrete to settle nice.
I'll use some plastic piping to bolt plywoods together as tie rods.
I need some kind of oil for formwork not to stick on the concrete,
I hope it goes well. Any thoughts
