Wadikus
Hey guys thanks for taking the time to answer my question,
So i left my bike in the garage over the winter and I (irresponsibly) did not lube it so the chain is real stiff and has some seized links and sounds horrible.
I want to change the chain, I've read that the stock length is 118 links, I can get a DID VX 118 length from Canadamotorcycles, however the 120 link chain is cheaper. Should I just go with the 120 linker and have my mechanic break 2 links off? or will this cause issue?
Should I change the sprockets at the same time? they seem to be in good shape, no shark teeth, still up right and have the flat ridges on top.
Thanks!
Wadikus
Also and on a completely unrelated topic, whoever owned the bike before me got lube on the rim and now the rim is stained with lube, anyway to get those stains off?
Thanks!
Thanks!
Wadikus
Thanks!
