clutch
socker77
Ohio
I have an 06 with 7,300 miles on it. I have the clutch cable adjuster at the handle almost all the way backed out and the clutch still grabs at the very end of me letting the handle go. I was wondering if that would be just a worn clutch cable or do i need a new clutch all together.
DownrangeFuture
Electronic Repair Genius
Houston, TX
The pull length can also be adjusted at the top of the tranny. Not sure exactly how, but I've run across it a few times thumbing around in the manual for different stuff.
The cable also has a center adjustment section. Lift the tank and look down between the frame on the left side. You see another adjustment between the the cable sleeves.
