liamstears
Evening all
Did some bits to the bike today and to finish I decided to balance the throttle bodies
After doing it and having them all pretty close at idle the bike does seem smoother to ride and a lot of the vibration I had before has gone so seems to be running right but have a couple of concerns
Firstly I decided to remove all 4 sync screws and start from fresh as I think I messed it up last time I did it and noticed all the screws had a black liquid of some description on them, is this normal? I cleaned them and put them all back in fully then backed them all out about 3/4 before syncing
Syncs fine at idle but when revving the #3 cylinder doesn't seem to pull the same vacuum, it's pretty close up to around 3000rpm but as you get closer to 4000 number #3 seems to stay a lot lower than the rest, I did try spraying some Carb cleaner around the boots and hoses of #3 but couldn't find anything
Should also mention I recently had the local shop check valve clearances and was told all are in spec and the plugs were changed at the same time
Please see this video: https://youtu.be/7RAnf6V1bVQ
Is this normal? Or do I have an issue here? Appreciate any help
