Fred
M em b er e d
I promised that I would do this a while back. And then I didn't. Sorry about that.
This is how to set up an FZ6 with true dual headlights. That is, two high beams, two low beams, and both headlights run through relays.
Why do it this way?
You get the best beam pattern, and the most visibility, especially when you flash your lights since both lights are blinking high/low. And you just feel better about yourself when both headlights have two filaments. I gained two inches in height and my cholesterol dropped to 65 after I did this mod.
Let's compare the existing headlight modifications to see their advantages and disadvantages.
1. Biker_Dude43's headlight mod.
http://www.600riders.com/forum/how-tos/1663-bd43s-07-headlight-mod-part-1-a.html
http://www.600riders.com/forum/how-tos/1666-bd43s-07-headlight-mod-part-2-a.html
Pros: The cleanest headlight mod by far. One wire plugged into an existing connector to bring the right side low beam into operation.
No increase in current usage over stock high beams.
No increase in current through the headlight switch.
Cons: The left hand bulb is still an H7 (single filament).
Making the pin for the factory connector is a pain in the butt. (But Biker_Dude43 did produce a run of wiring harnesses that you could just plug in. I don't know if he still makes them.)
2. Cashcrzzy's H4 bulb modification.
http://www.600riders.com/forum/fz6-...cation-making-h4-bulb-fit-into-h7-socket.html
Pros: Allows you to fit a dual filament H4 bulb in the left side headlight.
Cons: You need a grinder or good tin snips to modify the bulb.
You need to make a spacer to sit between the bulb and the spring clamp that holds it in place.
Depending on how it's wired, it can have all four filaments on at once. This doubles the current draw, and the FZ6 charging system is not all that powerful.
Even if wired so that the lows shut off when the highs are on and vice versa, this modification doubles the amount of current passing through the high/low switch on the handlebars. This could shorten the life of the switch due to heat buildup and faster corrosion. The fact is, nobody but Yamaha knows how much current that switch is meant to handle.
I should mention that my bike is wired this way. While I have not burned up my headlight switch, I do intend to switch it over to a relay setup in the future.
Both methods have good points and bad points. So the plan with my guinea pig motorcycle (AKA Hellgate's FZ6) was to combine the two methods and add relays to protect the stock wiring and switches from excess current.
Part 2 coming up in another post in this thread.
Why do it this way?
