Reclaimer033
I need some help. I don't know what to check next. About 5 weeks ago my bike started engine braking more than normal. Before, it would coast fairly well. After this started, I would let off the throttle and would end up way too close to the tank. I started searching the sites for answers. I tried adjusting the idle screw. That worked for about a day. Then it developed the dreaded TPS symptoms, idling around 500 rpm, stalling out when down shifting, fuel mileage around 30 mpg. I checked and the sensor had not been replaced. I got the sensor replaced and those symptoms went away, but the engine braking is still there. It would be such a big issue to me if it wasn't intermittent. It usually doesn't start doing it until about 5 - 7 minutes into a ride. I commute 30 minutes one way on city streets. It will start doing it, then three or four stops later, it won't. The two or three stops after that, it will start again. My fuel mileage is still down around 40 mpg. I used to get 48 - 50 mpg before this all started. I've changed plugs, and the air filter. Pulled off the exhaust and cat to make sure nothing was plugged up. (they are back on now) I have no aftermarket performance parts on the bike. It's stock except for my GIVI case on the back. Please help. What's next? Tear into the tranny? Oh, yeah: 2004, silver, 19,000 miles.
