F/S: 07'+ SwingArm Assembly
skooter65
Mainah'
Gorham, Maine
SOLD!! 06-30-2011
A much coveted, Gen II Swing-arm with rear axle, adjuster blocks, seals, bearings, and chain guard: Ready to bolt on to an 04' - 06' Model!
The part is in good condition with only normal wear from road debris. The areas which show wear (Mainly the top section and area to the right of the shock mount) are all covered once the rear hugger is installed. Original decals on the right-hand side. Very few visible marks on the right-hand & left-hand rails; although, it is not perfect.
Parts List:
Swingarm
Part Number: 4S8-22110-00-00
Factory MSRP: $673.33
Chain Guard
Part Number: 5VX-22151-00-00
Factory MSRP: $23.77
Bushing Sleeve:
Part Number: 5EB-22184-00-00
Factory MSRP: 36.26
Bearing, Frame Mount
Part Number: 93315-42523-00
Factory MSRP: $13.51 each
Seal, Bearing Cover
Part Number: 5JJ-22128-00-00
Factory MSRP: 14.33 each
Axle
Part Number: 5SL-25381-10-00
Factory MSRP: $58.72
Chain Adjuster, LH
Part Number:5SL-25389-00-00
Factory MSRP: $18.72
Chain Adjuster, RH
Part Number: 5SL-25388-00-00
Factory MSRP: $32.57
Axle Nut:
Part Number:90185-24007-00
Factory MSRP: $18.64
Axle Washer:
Part Number: 90201-25020-00
Factory MSRP: $3.44
Total MSRP: $921.13!!!
Asking $150.00 o.b.o + shipping (Please feel free to message me for a shipping estimate. FYI: Box will be approximately 30"L x 16"W x 8"H @ 10 Pounds, Shipped from zip code 06379)
Thank you for looking and please contact me if you have any questions!
Scott
[email protected]
Photos:
jrevans
Old-School Member
Eastern Pennsylvania
jrevans.fbody.com
That's a good deal folks!
If you're looking to upgrade the looks of your 2004-2006 swingarm and hate the crappy earlier chain adjustment mechanism, buy this! :)
I did the mod and even cheaply painted it to match my 2004 frame color, using Rust-Oleum Professional High Performance Enamel. Color code is "Aluminum 7515" (picture attached).
I cleaned and scotchbrited the swingarm before painting and the paint is holding up fine after over a year.
skooter65
Mainah'
Gorham, Maine
Thank you sir for the free bump!!
As I'm sure others are interested; would you happen to have a photo of the painted swingarm?
:thumbup:
Bakchos
Yamahaha
Canada
Just came back from my brother's house to show off, he tells me "should the chain guard be hanging like that ?"
oups, lost the bolt that holds the rubber part on the swingarm, good thing i have one on the old swingarm :cheer:
Should have check that bolt but it was getting late ...
