FS: R6s Forks + Spacers
thisisbenji
Wadsworth, IL
For sale:
R6s fork, spacer kit, axle and axle nut.
$350 + shipping.
Note, the spacer kit is missing one of the bolts that holds the fender on. It rattled out on me, but the fender was fine without it. You can pick up a replacement at your local hardware store.
major tom
durango co
I'll buy these I assume ny front fender (08) will fit? Will you provide some kind of instructions on the order and layout of the custom spacers?
thisisbenji
Wadsworth, IL
Lot's of good information on these forums, here's a couple to get you started.
http://www.600riders.com/forum/fz6-mods/29543-r6-fork-install-another-one.html
http://www.600riders.com/forum/fz6-mods/28956-r6-fork.html?highlight=fork+install
Really though, everything bolts up without much explanation. You can really only put the spacers on one way, if you mess it up the axle won't even mount up.
The hardest bit is that you do have to cut your front fender, but once mounted the cut is not visible. Even with my stock forks back on I still can't see the cut.
