sxty8goats
[ame=http://www.youtube.com/watch?v=1e4Esyxujtg]YouTube - MVI_1360.MOV[/ame]
Video shows it in action. Not really happy with the light output but it was cheep for the experiment. Using a Custom LED relay to control the flash rate.
You can see a normal bulb type flasher on the left for comparison.
The LED is one of those advertised as a 14 LED signal. It has 14 LED's in 4 groups. I simply lifted the resistor for the middle group of 5 LEDs and attached the third lead to that. Wired up as"
Signal to Bike
Yellow to Black/white
Red to Black
Black to Red
Red to Black is the running light and the wire I hacked in.. Yellow is the positive lead in on the LED. It runs to a diode on the LED which then distributes the current to 4 resistors. These lead to 3 or 4 LEDs each. I pulled the middle resistor and soldered the read lead directly to this resistor. It no longer had the polarity protection of the diode.
I'm going to go take it out now and put the bulb signal back
Signal to Bike
Red to Black
Black to Red
