My bike's been misbehaving the last few days.
Leaving the office today it cranked (quickly) for 4 seconds.. nothing. Started right up on 2nd try.
Few days ago (1st cold morning), it started right up and immediately died. Would not re-start on 2nd try. Restarted on 3rd. I let it idle for 20 seconds or so.. downshifted and it died again.
This pattern has happened 4-5 times so far, but recently it's happening too often for comfort.
Things I've done so far:
1. Ran Seafoam through several tanks.
2. Checked battery terminals.
3. Took apart engine cut-off switch, cleaned and reapplied dielectric grease (but really it was in very good shape to begin with).
Things I've checked:
1. Oil level (good).
2. Coolant level (between min and max).
3. Clutch switch (looks clean.. contacts are fine).
4. Sidestand switch (looks clean.. pops out with no delay).
About the bike:
27.4k miles.
Last TB Sync: 7.5k miles ago.
Last spark plug change: 7.5k miles ago.
Valves have never been adjusted (26k is when the manual calls for it, but nearly everyone on FZ1 forum says their valves are within spec when checked at 26k).
Thing I noticed when it fails to start: exhaust is definitely rich (no spark??)
So.. if this was your bike, where would you go from here / what would you check next?
Thanks!!
About the bike:
27.4k miles.
Thanks!!
