Dram45
I noticed some wiring on the rhs of my 07 FZ6sa looked bodged, so I set about removing insulating tape with a view to tidying it up. I noticed that it had been 'modded' but the wire cut, so I removed this and replaced the light's connector block with a new one from Halfords. Left is works as normal. The rhs headlight light no longer works and neither does the rhs indicator. Here's a rundown of what I've checked...
1.'mod' removed (wire from spare connector on rhs light to green/brown switch wire)
2. rhs connector replaced
3. headlight bulb and indicator checked and good
4. two new connections for the replaced block checked and sound
5. with rhs block out, 0v across pins on 'dip' and 12v on 'full'
6. continuity of earths appear good
7. voltage drops to 0v across pins when tested with bulb in place, engine running and switch on 'full'
Yes, the engine was running when I checked the bulbs
Any ideas welcome...
