Help me with the batery!!
jmoir
Guatemala
Hi good morning im new in here!!!
im from Guatemala and i Would like yo buy a FZ6,
but i have a question, someone is selling me a fz6
but they say that the battery is not charging, and they say
that is something like the alternator in the car, i want to now
how that's call on the fz6 (the alternator function on bike), and if is expensive or not?
can be a serious problem??
thanksss!!!!
sorry my english!!! jejeje!!!!:D
Looks like your 1st post so :welcome: to the forum! :)
Also there may be other problems like the regulator rectifier. There are tests you can do to the stator. Do a search and you should find info and procedures to do the tests.
Post #14 here----> http://www.600riders.com/forum/garage-mechanical-help/42402-battery-not-charging.html
What some one guesses is wrong and what is really wrong can be 2 very different things.
Has the battery been charged and load tested?
greg
UK Luchador
Stockport, UK
if only the stator is broken (you will need to check and find out) then you can rebuild it by hand for maybe $30-40 (main cost is copper wire and some epoxy resin). I made a tutorial on this last year
there are 4 main things it could be:
- bad regulator/rectifier (RR)
- bad stator
- bad battery
- a bad connection or earthing problem somewhere
the first two are probably the most likely, it could also be a combination, if the batter has had charging problems then it could damage it.
One important tool you will need is a multi-meter to try and diagnose and isolate the problem. A motorcycle battery charger would also be useful (most car ones will damage a bike battery)
jmoir
Guatemala
thaks for your help!!!!
and the strator and the regulator its the same than the fz6r???
i would like to buy one in amazon or ebay!!! but i only see for fz6r!!!
i dont now how is the bike, because im in guatemala and the bike in US!! jajaja
an uncle will go and see it for me!!!
do you have a part number????
Erci
Howie Mandel's evil twin
Pittsford, VT
For FZ6 S2 (2007+): STATOR ASSY 5VX-81410-00-00
(#6 in image)
greg
UK Luchador
Stockport, UK
the regulator/rectifier is a single unit and is underneath the tank hinge
the stator is on the left side of the engine
iSteve
MA USA
www.flickr.com
Before you start buying any parts charge the battery and see if it can hold a charge. Although you may get the impression that that charging system components need to be changed and that might be, the battery is the most likely part to go bad.
jmoir
Guatemala
thanks isteve!
they charged the battery and works fine (aparently), until she its out of charge!
i will check if the sistem is charging the batery!!!!
Thanks!!!
