cmdb
I've recently replaced the ECU on my bike, and the new ECU came with an entire set of locks and keys so that the immobiliser will work and still function.
The immobiliser seems to have 3 components: The key with a chip inside it; the transponder ring that sits around the ignition switch; and the ECU itself.
My question is, is the transponder ring itself coded or does it simply read the code from the key and send it to the ECU? I.e. can I just take the chip out of the new key and have it work with the new ECU, but leaving the old transponder ring in place? Or must all 3 match?
Changing the transponder ring involves disassembly of the bike, and if this won't work then I don't want to hack apart my keys for no reason!
Thanks
Thanks
