Morimoto Mini H1 Projector Setup (H7 ONLY)
outasight20
Long Island
I'm going naked and only need the H4 half of my dual projector setup, so I'm selling the H7 (low-beam) side. Of course this is a bi-xenon projector and has wires for high beam activation installed.
Includes ballast, 4300K bulb, projector with all necessary mounting hardware and washers, "Gatlin gun" shroud, and power connector.
Would be great for a naked conversion or to replace the stock H7 bulb and retain stock halogen high beam.
Asking $65 shipped in the US only.
Thanks
NOTE: Requires disassembly of headlight lens assembly for installation. Not difficult, but takes a few hours.
You could also fabricate or buy a washer to make this work for an H4 socket.
outasight20
Long Island
So, can this be used for Naked conversion headlight kit?
Yes, as long as there is room for the projector, but most single headlight naked kits use a H4 socket for low/high beam, and this has an H7 adapter. You could fabricate a new adapter pretty easily.
