- Joined
- May 6, 2014
- Messages
- 1,980
- Reaction score
- 1,929
- Points
- 113
- Location
- Amoungst the Twisty Roads
Both of those wires go to the main switch. The red is 12V (unswitched) from the battery/main fuse to the switch and the orange with the black trace is 12V (switched) from the switch to all electronics on the bike. Neither should be outside of the harness. If they are outside the harness you might have a little fuckery going on with your wiring from a previous owner.
Check the wires for and signs of rubbing where the insulation is missing, and check the connectors at both ends for corrosion.
