crabbypants
Okay, so after owning the bike a while, I realized that the signals in this thing are quite FUBAR. The previous owner put in a bunch of aftermarket lights and It seems he did a real job with it :spank:
Here is the setup that I bought the bike with:
So we are talking about 4 lights total on either side that blink when the signal is on. However SOME blink at the accelerated rate, like I have read happens to so many people, EXCEPT the front signals, somehow those blink at a normal rate.
The rear signals are even more odd, they seem to blink at a slightly faster than normal rate, but will pause every once in a while.
Like: *blink* *blink* *blink* *blink* ----------- *blink* *blink* ------*blink* blink* *blink* *blink*
There really doesn't seem to be a pattern at all.
The POD and integrated tail light signals blink fast along with the signal indicator light.
If all of these lights consistently blinked fast, i would say get the electronic flash relay and that should fix the issue, but since they are so erratic, I don't know if that is going to fix it. Either way I ordered one, but I'm wondering if there is more demons at play.
Also note: Hazards do the same odd patterns as all the lights do when turn signal is on
- Front and rear signals replaced with low profile LED signals (the amber flush mount type)
- POD lights installed in the corner of the headlights (might be LED?)
- Rear taillight replaced with LED taillight with integrated signal
