vb7prog
so I took bike to shop to get new rear tire, and they tightened the chain too tight, but I know the procedure and its hasn't been too big of an issue, so I decided to fix at home. Here is the issue:
I have an impact wrench 425 ft-lbs of force, when I try to undo the axle bolt, it spins, so I use the 34mm helper wrench for the other side, but the torque gun wants to spin the helper wrench so I have no way of applying useful torque without seriously hurting my hand/fingers, at 25 ft-lbs the helper nut spins, but i cant get them unstuck, I have undone the nut in the past 2-3 times and this hasn't been an issue, what causes the nut to be so tight with the axle, how should i proceed?
