- Joined
- Feb 7, 2009
- Messages
- 12,557
- Reaction score
- 1,210
- Points
- 113
- Location
- Cape Coral, Florida, USA
So, what was this all about where did you find a cure? That $$ injector cleaner perhaps or ???
The vib was the right side of the seat. I actually sent theseat off to Spencers down here for his magic.. Helped but didn't fix it.
I bought the Carbtune shortly there after as I was going to sell the bike it was that annoying.
Anyway, after a good sync, a re-check and re-adjust at 4k, (within 3mm's across the board), nice and smooth.
When its about ready for a re-sync, it'll start getting the right side butt vibs while relativly cold. Once warmed up, it stops. When it does it cold and hot, the Morgan Carbtune comes out..
As you know, it takes very little effort when adjusting those screws, there not tight at all. I suspect that's probably the issue, they vibrate just slightly and throw off the sync over time..
I'll probably get some very light duty locktite (think its blue, I found some designed to seep into the threads) and put just a drop down each adjuster screw. Just enough to keep any engine vibs from allowing them to move BUT I can still adjust when needed...
