tigrtraps
Think that title made sense, I'm learning as I go. Recently bought a used '08 FZ6. After the first 10 mile ride the front brakes seemed a bit squishy, and I decided to take them apart and clean them.
Problem No.1; the bolts holding the caliper to the fork were hand loose. Yup, I loosened all 4 of these bolts with my hand. Weird and scary, time to look at the brakes.
Problem No.2; my used 2008 FZ6 has 2 piston brakes instead of the stock 4 pistons. Brakes show some minor rust in the pistons but seem to be working fine. Clean them up, put them back on and TIGHTEN the bolts.
Problem No.3; bike won't roll an inch now. Front brakes are completely locked. WTF? So I loosen the front caliper bolts back to 'hand loose' and the wheel can move, brakes will stop it.
My conclusion is since the S1 brakes need to be free floating, and I assume the rotors are stock on my '08 bike. This means that the bolts will always have to be loose so the calipers can actually work. As I said, I'm learning as I go. I'm not even sure if the rotors are different from S1 to S2 brakes on the Fz6.
This is very much a problem as I'm not comfortable with a caliper bolt vibrating off while riding. Evidently the idiot that owned this bike before me was. When I put the bike on the center stand and spin the front tire by hand I only get half of a revolution before the 'floating' brakes slow the tire. So big question is, is there any way that these floating 2 piston calipers could of worked? I already have the correct calipers on order to me, and thank god the bike was cheap. Now I'm paranoid with what else was half-assed on it though.
