Speedo problem
Pagey
Tiger Boy
Hull, UK
Hi folks,
Just returned from touring Scotland and i have found that my speedo is between 4-6 mph to fast.
Can the speedo be re-calibrated by my Yam dealer or is there a simplier solution
Thanks in advance
ps the tour was awesome on my Fazer :)
Nelly
International Liaison
Co Offaly, ROI
Hi folks,
Thanks in advance
Use the search function, tons of info on this and speedo-healer installation.
Neil
Marcelor73
MD, USA
Hi folks,
Thanks in advance
4-6 mph error is typical. The only way to fix it is with a speedo healer. I have one on my bike and love it, but I got it because I changed the gearing. I wouldn't have bought it for a 4 mph error.
Sent from my DROID BIONIC using Tapatalk 2
mave2911
South Australia
If you do big highway mileage, go a 17T front sprocket. That will make the speedo accurate to within 1%.
Cheers,
Rick
ChevyFazer
Redneck MacGyver
ATL
Yamaha claims there speedos are off 5%-10% from the factory. Yet even though the speedo is off the odometer is dead on perfect, and in the process of correcting the speedo it will throw the odometer off.
+1 on the Speedohealer. Mine was off (read high) about 4 MPH at GPS indicated 60 MPH
You can adjust it so your speed is dead on, it also has a device that records your top speed . With the touch of a button you can re-set it (kinda cool)... It can easily be removed for your next bike should you change bikes as well..
As noted above, going a front sprocket tooth larger will bring it much closer and lower the RPM's on the highway, however I was very happy with the stock gearing performance.
BTW, Yamaha won't touch the calibration (its built into the bike, ECU), they may do the install of the Speedohealer and should be able to do the sprocket change. If you can raise the tank, you can install the Speedohealer. Plug it into the harness, set the calibration, re-assembly, go ride...
