Temperature flashing high
Tonyp83
Middlesbrough
So I took the front cowling off my bike to paint them when I have put it back together the engine light is on and the temperature gauge is flashing high also the day running light doesn't come on till I start the bike up checked all the electrical connection and they are all fine any ideas on what it could be also the bike starts fine
Thanks
Ant
Welcome to our great forum?
The headlamp circuit does not activate until the engine has started but the running light circuit is generally a separate circuit. Maybe your running light circuit is tied to your headlamp circuit by design in your country? In the US models the running light circuit is active when the key is turned on but the headlamps are off.
Your instrument cluster should have 2 separate plugs. Check that they are clean and plugged in securely.
