has anybody here done or seen a dyno of a descently modified fz6? I know my r6 was running around 107 in 2003 stock! the claimed HP of stock fz6 fluctuates between websites and postings, but ive seen from 84 all the way up to 98.... is this because of the type of dyno. or just crappy reads?:Sport:
Type of dyno and the conditions in which the measurement was taken, ie: heat, humidity, etc.
No one dyno will read exactly the same from run to run, most are pretty good however and you should use the same dyno each time. Dynos are great for relative comparisons, ie: Add an exhaust and see what the difference is, etc. A drag strip will do a similar thing however the variables are too great, rider, track and weather conditions, etc. The dyno will also allow you to see other areas of engine performance including, torque, mid range performance, shape of the power curve, etc.
Dynos are just one tool in tuning your engine. Other tools include O2 sensors, 4 Gas EGA, plug checks, etc.
The key is to find a shop/professional who can help you make good choices to get what you want out of a tune.
