Yasko
A hammer, coat hanger, and tape.:BLAA:
Rear axle nut on 2007 FZ6 is 32mm. Don't ask me how I know!
- - - Jim
Most problems can be solved with a suitable application of throttle.
So, what is the size of the front axle HEX head? My 06 does not have a nut on the front. It is a hex head. Caught me off guard.
19mm - you're best off getting something like this
please note I've absolutely no idea if that particular item is any good, but the picture illustrates what you're looking for.
Lies! get a spark plug socket! Put an extension through it backwards and you're golden, for a lot less than the multitool!
For me, an 18mm spark plug socket had the 19mm OD required for the front axle!
That "bolt & nut" thing will work, although it looks like a sloppy fit. Just head to your local hardware store
and pick up a threaded rod connector. It cost me less than $3 for a perfect 19mm outside diameter.
