Turn Signal Switch; Stuck Hazard Toggle
namruso
Kaneohe, Hawaii
Out of no where, the toggle button for my hazard seems stuck. Is this common? Is there a way to open it up and see if anything is obstructing it?
Thanks ahead of time,
Sean
No, it's not common Sean.
Never had it apart but it was when assembled. (IE, open it up!)
You have nothing to loose.
I would disconnect the battery and slowly pull it apart paying close attention.
Should be pretty obvious...
Please post back with what you find..
BTW, should that switch have a broken plastic piece in it, you have to replace the entire left handlebar assembly.
You check the F/S section below or PM Skooter65 , he's parting out several bikes..
namruso
Kaneohe, Hawaii
Since everything else worked, it passed safety. I can engage the hazard if I bash in the button and pull it out with pliers, so they said "then it works!" Haha
