So I know the FZ6 has an R6 engine in it, but its detuned. How hard/expensive would it be to turn that FZ6 engine into a full-bred R6 engine once again?
hmm, yes ive seen that thread. its actually what prompted this thread. is it just bigger cams then?
Cam characteristics are generally related to lift and duration so the lobes are machined differently to provide how long the valve is open and how much it is opened. Our FZ6 cams provide for a tamer performance curve as well as a computer map that's different. I believe those are the only differences in the FZ6 and R6 motors. A Power Commander will take care of the computer part and an R6 cam will take care of enhancing how the engine gets the mix in and out. It's actually a very complex science and Wolfman is also doing a bore kit so he can get another bump up in horsepower and torque.
Cliff
i haven't ridden an R6, is there that much differance in performance?
The solution to every thread about people wanting to turn it into an R6 is always the same:
Buy an R6.
We don't have ram-air,
Nobody that doesn't fly a jet has ram air. At best they have a freer flowing cold air intake. The Ram Air concept is a sales pitch. Can a really good intake improve HP by a few percent? Yep. But the sales pitch of ram air tries to imply that you are forcing more air into the motor, resulting in a slight supercharge effect. There simply is not enough compression available at any land speed that will allow this. The motor is pulling air in much faster than you are supplying it by moving into the air stream. We have been arguing about this for ever on the Pontiac forums.
Buy an R6.
