Weird noise from front left
FYI, thru some PM's, it was determined there is some play at the triple and the lower bearing NOT changed out, the top was with All Balls.
Triple will be pulled and lower bearings replaced and adjusted without the triple clamp on.
Note: the lower bearing did have visable wear on it.
