ticktock
Well, I finally went naked.
Here's the list of what I've done so far:
1. Custom headlight from BKMOTO. CCFL Halo and Bi-xenon HID. Installed a rocker switch on the handlebar to isolate the halo as low beam and the HID/secondary lamp as high beam.
2. I didn't like the built in blinkers in the headlight at all, so I mounted my own into the headlight brackets I picked up/modified and painted.
3. Rhinomoto bar ends with CRG hindsight knock off bar end mirrors. The eBay bar end mirrors I got didn't fit right... so I had to mill them down and paint them to get them correct. Probably worth the hassle though considering I think they were only $30. I'll see how they hold up over time.
I think the best part about everything is that I'm keeping all of the original wiring harnesses. Since I already did the BD43 dual headlight mod, I'm wiring everything up with a H4 connector and leaving everything stock. That way if I ever want to go back to the fairing for some reason (or I sell the bike), I can put it back together with ease.
FYI, I also used LEAN69's speedo mounting bracket. It's quite nice, but I did have to drill out the main attachment hole because it was too small for the stock bolt to go through.
I should finish all of the soldering/wiring and routing in the next few days. So far I like it much better than stock!
