- Joined
- Apr 6, 2009
- Messages
- 1,318
- Reaction score
- 44
- Points
- 0
- Location
- pittsboro, nc (near raleigh)
i have some wiring i need to do to clean up my fairing and add my stebel horn.
here is what i currently have.
now here's what i want to do
here's where i need help. i want to do this a clean as possible and with as few parts as possible. so if you could follow this and let me know if this plan would work.
the only other thing for me to figure out is hooking up the stock horn to the "kill switch" push-button on my "heater" switch i'm adding. any suggestions for this?
i hope that all makes sense. some of this is hard for me to think through since there's so much going on and wiring a bike or car is not something i do on a regular basis. any guidance you guys can give will be greatly appreciated.
- projectors - all wired directly to the battery
- heated "under"-grips - wired directly to battery (no relay) but doesn't matter because they haven't worked since i put them on. i put them on last year and didn't have time to take everything apart and trace out the issue.
- first, i got one of these
the plan is to use the hi/low switch for my heated grips. and to use the kill switch for my stock horn to give friendly beeps while on campus and other places. - next i'm going to add a stebel horn.
- the other thing i plan on doing is running a terminal strip and fuse box to the fairing to clean everything up.
- first, because the grips don't need to run through the fairing i plan on hooking up from the battery -> fuse (amperage?) -> relay -> switch
- second, i want to send some wires to the terminal strip in the fairing to run the stebel and projectors. so i don't crowd the battery area i'm thinking... battery -> +/- wires to fairing -> fuse (30 amp?) -> terminal strip.
- then i'd plug the projectors into the fuse box/terminal strip.
- off the fuse box/terminal strip i'd run the relay for the stebel. will it also need a dedicated fuse? if so, what amperage?
