Wiring of rear turn signals.
seanalan329
Tucson, AZ
Hey guys, I need a little help. The previous owner removed the turn signals and now I'm adding some new ones but don't know which wires to connect them to. I think they go somewhere in this general area. I appreciate the help!
[/URL][/IMG]
See that gray connector and that black connector? They both look the same except the color. One has a dark green wire and a black wire. this is the right rear directional The dark green wire is the signal and the black is the ground.
The other one (left signal) is a chocolate wire (brown?) and a black wire. Chocolate is signal and again the black wire is ground.
Let us know how you make out! :)
seanalan329
Tucson, AZ
That's what I thought, I just didn't know left from right. I lost daylight, so I'll have to wait for tomorrow. Would I be able to cut out those connectors since my turn signals don't have the male side? Plus the black one is busted.
Yes! Just go to the other side of the plugs. Just get rid of those plastic plugs and make your own connection. You could use bullet type connectors which is what Ive done for a lot of bikes that were boogered up. :)
seanalan329
Tucson, AZ
They're LED signals, so I would need some resistors too right? If so, are there any common ones that I can pick out at a local store?
Super Bright LEDs - Electronic LED Flashers Specifications
At the bottom of the page. LS1-S-Flat.. :) ***$8.95*** :rockon:
Left side of your fairing, inside, down low, is the flasher location. It's in a rubber mount that slides onto a plastic tab. Wiggle it straight up and off the tab and it will hang down to swap out the Flasher relay.
The electronic flasher will flash at a steady rate regardless of load. No resistor are needed. There is only one flasher. This is the same flasher that is used for the 4 way emergency lights
Also remember the LEDs are polarity specific. If it doesn't light the wires may be reversed. It won't hurt them if they're reversed. They just won't light.
seanalan329
Tucson, AZ
I've got one ordered, thanks. Now I just need to find the relay. The previous owner removed the fairing. Hopefully it's tucked away under the tank, cause I can't see it anywhere else. I'll check when I get home.
seanalan329
Tucson, AZ
I got my relay in, the previous owner cut out the the OEM relay. Do you know what color the wires are?
Yes. Brown with green tracer goes to your red wire on the flasher relay. Brown with white tracer goes to the black flasher relay wire. :)
