- Joined
- May 8, 2008
- Messages
- 15,358
- Reaction score
- 1,605
- Points
- 113
- Location
- San Diego, Ca.
I got a set of these. GP-Thunder Pair 1157 2057 48 LED Light Bulbs White ++++:eBay Motors (item 400070881960 end time Oct-01-09 15:40:08 PDT)
They come in a 2 pack. They are way better than the first LED 1157 replacements I tried. I did order the white and the color is fine.
I know there was some controversy over whether these should be the red or white and I do understand why either of those theories could be correct. The red tail light Yamaha lens may be different from other OEM or aftermarket lenses because mine works fine with bright white LED's and the color output looks normal. Other OEM or after market lenses may need the red LED's because the bright white LED will show up a different color than you want. This is probably dependent on the lens.
The OEM lamp has a hot spot and gives the illusion of being a little brighter but the lumen output of the LED's seem greater and more dispersed.
The lamp comes in a 2 pk so today I'm going to try the other lamp in one of my stock front signal stalks and if it works well I'll order another pack.
Thank you all for your input and info on this. I think because of weight saving in the bike industry the charging systems on our bikes are a little on the weak side and I like saving wattage where ever possible and a good LED substitute is a good solution.
Cliff
Cliff
