Over the past couple years several members have ran into trouble from low batteries do to prolonged idle time. Most have dual head lights but not all and if the bike is below 1800 RPM for too long the battery discharges to a point of not being able to continue operation.
My goal here is to discuss some design options to A) warn the rider the battery voltage is an issue and B) potentially drop one of the dual headlights to reduce the load. This last choice comes at a RISK and a good deal of consideration is required before chopping the headlight power. It could be the only safe bet is USER INTERVENTION vs automation.... The other option is too increase idle RPM with a simple solenoid but once again this comes at with RISK!!!
Initially I was looking for an Off The Self (OTS) solution but didn't find anything except for home and RV use which is overkill for our needs. I did find an Integrated Circuit (IC) that does most of the logic detection for us. We simply need to give it some limits to work with. The cost for the IC is close to $5.00 alone. The rest of the cost would be for a housing, resistors, diodes, FETs, and relay or switch assembly. So if not sourced correctly, the cost could easily be over $40 in materials alone. Is that worth it?
Here is one option and I'd guess there are many others. So if someone know of something, feel free to share.
http://datasheets.maximintegrated.com/en/ds/MAX8211-MAX8212.pdf
From Manufacture:
Maxim’s MAX8211 and MAX8212 are CMOS micropower voltage detectors that warn microprocessors (μPs) of power failures. Each contains a comparator, a 1.5V bandgap reference, and an open-drain n-channel output driver. Two external resistors are used in conjunction with the internal reference to set the trip voltage to the desired level. A hysteresis output is also included, allowing the user to apply positive feedback for noise-free output switching.
The MAX8211 provides a 7mA current-limited output sink whenever the voltage applied to the threshold pin is less than the 1.5V internal reference. In the MAX8212, a voltage greater than 1.5V at the threshold pin turns the output stage on (no current limit).
The basic schematic is very simple and needs only wires, resistors, and an LED to notify the rider there is a problem. Cost could be as little as $10.
The built in hysteresis (trip margin of detection) could use an electrolytic capacitor (RC time constant) to keep it latched for short period of time, but an actual circuit in addition to the basic one here would be best just so the light doesn't flash on/off when hovering at the trip point. Also to drive a relay (head light relay if someone wanted to drop one head light), would require a small signal amplifier like a MOS-FET device to drive the relay.
I just wanted you to see how simple this is with one basic component.
This is an open discussion for NEEDS that could be employed to help reduce dead batteries BUT SAFETY MUST COME FIRST! Please try to stay on topic. Thanks!
