That video was much better, thanks...
The cold start high idle may be a little high, but acceptable, the rest of it normal short of the end.
When you revved it, seconds later (just about at the end), the temp gauge dropped down.
**The water pump is
pumping more volume with more rev's, that
may be the reason however mine doing that(while stationary, revving), will increase the temp, NOT drop.**
How many
temp bars did it normally run at, normal running about?
A bit higher than shown in that video? (
S1 owners, PLEASE CHIME IN).
When was the coolant last changed out?
IF the temp gauge was running a bit higher normally(before issues), and is making wide swings in the temp, I'd be
leaning towards the thermostat being stuck open.
The video, somewhat confirms this. Cold start, high rev's for about a minute(normal), the rev's drop(normal), the temp gauge eventually shows one bar(normal).
When you rev it, the temp drops, not normal... Back to the above
**'s ^^.
If the thermostat is
stuck open, the extra rev's is allowing the coolant to flow and cool the engine quickly vs REGULATING the amount of flow thru the thermostat..
The thermostat should keep the temps from jumping about, gradually rising and lowering depending on the riding conditions.
The FSM shows thermostat replacment requiring throttle body removal, etc. One member was able to change his out his thermostat strictly by working under the TB's and not removing anything else(short of the hose). It was tight but doable.
Did you check the frame to engine mounting bolts?
You are getting a little more RPM variation in tha video. You may want to run a couple of tanks of Chevron Techtron fuel system cleaner (on the heavy side), it may help smooth things out a little.
Re 5000, 5400 RPM's, what is happening? While riding, with some load on the engine, misfire or ?
Another possibility but NOT likely (from what I'm seeing) is the temp switch in the engine itself. It can be tested electronically:
Part #20;
Yamaha Motorcycle Parts 2005 FZ6 - FZ6ST ELECTRICAL 1 Diagram
Randy, your thoughts? [MENTION=15974]FinalImpact[/MENTION]
Double click to enlarge;
