Front brake switch
FB400
Super Member
Long Island, NY
I needed to replace the front brake switch after doing a test with a jump wire it was determined the original one is not completing the circuit when pulling the lever and actuating the switch.
So I ordered and received a replacement from boats.net. I ordered off of the right parts schematic.
What arrived looks nothing like the original. this doesn't look like the plunger is going to line up and be useable!
Anyone been down this path? able to get this switch to work or is it just wrong?
Thanks
Tom
Are you sure you have the right year? Your 2006 FZ6is S-1 version and this should be the correct part number Yamaha 4HM-83980-00-00 - Front Stop Switch Assy : Ron Ayers
You have 3YX=82917-01 you should have 4HM-83980=00=00
I just checked and both S1 and S2 FZ6 use the same part number so your part may be for a different bike altogether.
This is a replacement switch I ordered off Ebay after the original died on me, it lasted maybe 6 months before it died too and I immediately ordered a new one. When the new one arrived I opened the first one from Ebay to find it's just a couple of metal bits and a spring which was a bit of a let down considering how much the thing costs.
I checked it several times - I think the parts schematic is just wrong. those Dicks at boats.net gave me a run around and asked me to write an email.. blah blah.. wasted an hour of my time today and still refused to refund me for the shipping. first time ever I had a problem ordering parts for my FZ6 when using the parts schematic
Edit: thanks all for the responses. I will order the correct part #
I just sent back a $360 belt tensioner to Boats.net (for my Yamaha 150 HP, OB engine). I called and had to send an e-mail
with a pic of the part. They responded quickly, got the ok. I should see a new one in a couple of days (got a UPS return label).
The tensioner came apart while installing it, (a combination of an internal spring, hydraulics's and bearings)
If they sent the wrong part, they should be picking up the shipping.
This is the e-mail address for the supervisor of boats.net (same company as Partzilla): [email protected]
I ordered on-line as well, thru the parts fisch and also ordered a ft brake pad pin for the bike too....(at least I got that done)
Scott - thanks yes that is the address they gave and told me Jeff was the manager. I never heard from them then they sent an RMA with the cost only of the part. It's really annoying but I just want to get the thing replaced and don't have time for any nonsense
for sure it will work out. usually does. it's just that work is such a cluster right now.. didn't need added aggravation today.
I can still ride it making sure to use the rear brake as well as the front to light the brake light.. no biggie
UPDATE: Full Refund. weird uneven customer service! no email or phone call just a full credit to my paypal account. I had just mailed back the switch to them this morning. I was only expecting to get a credit for the part but they paid back the shipping charge.
