aiass
I've been having this problem with this bike for a long time and I cannot for the life of me figure it out. I'm going to tell the story of how it came to be. (2007 fz6n s2)
I first got the bike and no issues it was great until around a few weeks into it, I went to start it but didn't hold the starter long enough and it didn't start. I pressed the starter again and got the single click. I assumed it was just low on battery so I bump started it and it worked fine. Then intermittently it would start then not start, with the final(or so I thought) time it barely turned the engine over with a very low squeal and was not able to start it. I bump started it every time after that except for once or twice where the engine turned over once or so but not enough to fully start. Now a month or so ago my headlight went out and I checked the bulb first, replaced it, and the bike suddenly started great. It only did this once, and the headlight still didn't work. I turn it off and go to start again and I get the dreaded single click. I noticed when I was doing this that there was a wire going to my headlight that was exposed, it didn't look corroded or anything just exposed so I wrapped it with tape and went about my day. I then looked to my headlight fuse and saw it was out, I replaced it and my headlights worked fine. I've been trying to tackle the starter problem lately and here is what I've tried:
took battery to autozone and tested, their machine said it was good
cleaning terminal and all nuts holding it on to the starter motor
testing voltages (12.9 off, 12.5 on, 12.3 pressing starter, 14.3 running at all rpms)
tried a new starter and relay by just connecting it to battery but not installing it(gave me the same single click just slightly higher pitched)
manually grounding the bike by removing ground to battery and attaching jumper cable to frame and negative terminal(tried for both original starter and relay) and still got the click
One other thing is that part of me thinks it was originally a regular fz6 not naked because of the black tank along with the missing top light on the headlight but I'm not sure on this. Also the title says just fz6 but I'm not too sure if it would say fz6n (texas title)
The fuse going out plus the exposed wire in the headlight has me thinking this is a wiring issue but I have no idea where to start with any of that, does anyone know if the headlight circuit could interfere with the starter one or really just any ideas? I have a multimeter.
Thanks for any help
Thanks for any help
