2008 FZ6 Fuel Pump Replacement
marzrioz
San Antonio, Tx
I'm replacing the fuel pump on '08 Fz6. Hoping some one can help me out with a picture of the underside of their tank. Trying to remember which hoses go where. I apologize if this has already been covered previously.
Will this help?
You talking about the vent hoses/ overflow? There will each be one on each side of the tank. Make sure when re-installing, you pull the lower end as to NOT have any kinks..
Fuel lines only go on one way... The pump o-ring seal should be replaced too..
Getting the pump out, best to release the clip below and come out in two pieces. It'll go back in the tank as one (assembled)..
